YungICY
- Jul 19, 2013
So I think I finally got to the root of my lean condition issue. Today I pulled the spark plugs out and one of them was missing a good chunk of it. I replaced it with a good plug and nothing changed. This leads me to believe I have a chewed up valve or even a hole in my piston. Assuming its my valve and that piston isn't getting compression and not firing, my logic tells me that the o2 sensor would read a lean condition. Would I be correct in assuming this?
Question 2) this motor is an 88 (with a roller cam). I also have an 85 2.3 waiting for a rebuild. The head is in good shape but the cam and followers are shot. Is it possible for me to swap the cam, followers and lifters from the 88 head onto the 85 head (keeping the good 85 valves) and install the 85 head onto the 88 block?
Sent from my Windows Phone 8 using Tapatalk
