Leaf springs for 2in lift
86_LX
Mooresville, NC
1992 and 2004
Hey guy getting all my parts together, Im using skyjacker 2in leveling coils on the front I have heard these flex pretty good, skyjacker nitro shocks. Im wanting to get rid of the factory block in the rear, what leaf springs can I use to get rid of the block and still be level with the coils I bought? I want good flex off road, its a 92 reg cab short bed on 31 in tires and im going to cut and roll the fenders if I need extra clearence. Putting new leaf spring hangersmfront and rear. I was thinking of using the 64in chevy leaves but heard they would be higher then the front
Well if the rear is higher it just means you need to lift the front more!
I don't know how the 64's sit as far as height goes, but i know they have crazy flex capabilities.
if your truck is like most rangers then the back sits higher than the front already. you can swap in a set of explorer rr leafs to get about 1 in of lift with the block or you can ditch the block and put on a longer shackle, belltech pt# 6400, and that should allow you to be a little over stock height.
The explorer leaf setup would work, but IMO they are pretty stiff, I have run them before and i don't know if they would give enough flex.
thats what I was thinking, getting a set of explorer leaves then adding the main ranger leaf with the eyelets cut off, then maybe pulling the overload leaf out and adding a few more explorer leaves in it.
To be more specific, I ran full explorer leaf packs with the ranger mains cut off and added under the explorer main, though i did keep the overload in. That gave me 4" of lift, so minus blocks it works out right at 2". I could tuck my tires ok, but it was certainly no chevy 64 in terms of flex. That being said, it sure was an easy lift.
would it be easy to stuff a 31 all the way into the rear fenders? All im wanting to acomplish is better flex then the factory in the rear and to get rid of the factory block
Yes, my buddy Sunk ran the same leaves (explorer plus ranger) stock blocks, and belltechs under a 1st gen extended cab with 31's. I think the explorer leaves he got were a little more worn out than mine and he could tuck a tire pretty well, the problems he ran into were that even with 4 or 6" coils up front (cant remember) he could tuck the front 31's to the fenders. He did have pretty soft coils though.
Thinking about it now, with only 2" of lift, the explorer leaves will certainly allow you to tuck as far as the tires will let you go.
I am used to thinking of flex in terms of 6" lifts, and the flex you'd expect out of a 6" is a lot more than out of a 2"
You could run the 63" chevy leafs without your block and I bet it would sit level.
I have roughly 5" of lift up front on my truck. With the stock block, plus the chevy leafs and a 1.5" extended shackle, the truck has just a bit of rake.
If you delete the block and just do the chevy leafs it should be just about right. They usually net around 4" of lift, so if you take the 2" block out it should be good.
I had the explorer leafs before, they can't even compare to the 63" chevy leafs. I'm running just the 3 leafs, no overload in my pack.
