- Aug 14, 2007
- rocky river ohio
- Manual
i am not sure. i would think that the 2wd regular cabs would have a longer drive shaft because they have no transfercase and would have a two piece shaft. if it were 4x4 then i would think that it would have a 1 piece drive shaft. can anyone shed some light on this?
2wds dont have a carrier bearing as far as i know. the 4x4s that had one were the ttb extended cab rangers.
as far as fixing the truck you can get new spiders and still do one wheel peal burnouts. i would weld it if you or someone you know has the skills to do it. if no one can weld it i would order a mini spool they are under 100 bucks. driving a locked rear is difficult to drive and isent for a moderatly skilled drivers or those who are easily shaken, they will do dougnuts on you in a split second in the rain or snow. if you dont like it you can always replace the spool with new spiders. if you weld it you usually have to replace the carrier as well.
PS you are one lucky kid my brother had a dakota that he side steped the clutch at the redline it regularly and when his went it took EVERYTHING with it, c-clips,spiders,ring and pinion.
86
