Jake xadn
Hello. I have a 06 b2300. Can fuel injectors cause a issue at a certain rpm. 1500 to 2000 rpm. Below no problem, above no problem. Truck has 285,000 miles. Thanks for any help. Oh no codes are coming up.
Whens the last time it had plugs and a fuel filter?Hello. I have a 06 b2300. Can fuel injectors cause a issue at a certain rpm. 1500 to 2000 rpm. Below no problem, above no problem. Truck has 285,000 miles. Thanks for any help. Oh no codes are coming up.
Being in such a specfic rpm range almost seems like possibly a TPS...but it should throw a code.With in the last 2 months I have replaced. Fuel pump fuel filter coil plugs wires map maf air filter pcv m
Just drivingBeing in such a specfic rpm range almost seems like possibly a TPS...but it should throw a code.
Is it always that RPM even in neutral or is it load dependent?
