intercooler size/location for a 96 2.3t ranger?? who's done it, what fits?
stackz
getting ready to grab an ebay intercooler and pipe set but I havent even had a chance due to work traveling and weather (been raining like hell haha) to get out to the truck and look around on it and measure to see what size intercooler will fit, etc.
I know there's a few 2.3t trucks on here and a few have to be intercooled and I'm sure out of these, there's a few cheap asses like me that went the ebay cooler route :icon_twisted:
You wanna be really cheap go with the Volvo 740 IC. Fits like it was made for a ranger once you trim the core supports.
I don't know on the E-bay ICs, but IMHO 3" core is too thick. I have cooling issues because of my 3" core.
i got a 2.5 inch thick its 28.5 by i think 13 and it sits rite behind my bumper cant even see it which is wat i wanted.. its off ebay and only ran me 45 bucks ... then i went even cheaper with the tubing 2.5 U bends from jegs mandrel cut and weld with high pressure boots from lowes as i was on a budget but it works and dropped my intake temp from 310 to 120 range
Do you still live in Provo? I didn't think it got that hot there. I have held off adding a intercooler to my truck as I'm worried it will run hot in the summer time.
Yup, still in Provo. It gets in the low hundreds at the hottest here.
The volvo IC was nice that way because it was much thinner. Now I have 3" of intercooler right in front of 2.5" of 4.0 radiator, and the stock fan just wont do it, and that's with no AC. Maybe an electric fan would help.
I didn't realize that it got that hot there. I was born in Salt Lake City and lived in Moab but that was like a hundred years ago.
I have a 16" electric fan on mine now and personally I think that the stock fan did a better job at cooling things.
Maybe I will try a Volco IC if I can find one cheap.
This year wasn't bad, it rarely got over 100, but it does happen.
Volvo ICs are usually less than $50, so it shouldn't be hard to find a cheap one.
I didnt think the volvo intercooler would fit between the core support and radiator and still clear the fan??
or do you mean to notch the support where the evap core is located??
either way I've got 3 of them laying around from my svo and other mustang projects. This looks to be the way to go. as I've got a bunch of spare piping/connectors I robbed from the same volvos...
I just need to know if I can retain the evap core or not like I can with the ebay ones that I can mount in front of the core
I cant really speak for a 3rd gen, but 1st and 2nd you put the IC between the core support and radiator. The mechanincal fan is behind the radiator and the radiator remains in it's stock location, simply sandwiching the IC between it and the core support.
The trimming is done to accommodate the width of the IC, from end tank to end tank. It's really not much trimming, but it does need to be done. On my 88 IIRC the evap canister remained in the stock location. With my larger IC, it was removed.
got any pics of your setup Davis? I could use to install an IC here soon... my stock fan doesn't do it with my explorer radiator right now, although I don't have any proper fan schroud. I do have a Tarus fan sitting in the garage waiting for me to get a few relays wired up...
31x12x3 behind the radiator
heres my set up:
I have the exact same size and look at my avatar. I liked the look of it hanging down. Scares ppl
What year of Volvo 740 will have that IC? I have a TC IC but I don't want to use it because it will be subject to alot of under hood heat.
Unless you live in HELL or spend time driving around in forest fires an intercooler isn't going to make the charge air hotter.
at 15psi boost a typical turbocharger is going to be generating compressor discharge temps on the order of 300degF in 90degree ambient temps.
The efficiency of turbochargers is calculated against an ideal "adiabatic" temperature rise due to compression (compressing any gas ALWAYS creates a rise in temp) even a 100% efficient compressor would push air to 210F.
a typical turbocharger is 60-70% efficient and that'll push temps
to 300-340F.
An intercooler however is rated on it's efficiency by the percentage of
temp reduction it creates.
IF you have an intercooler inlet temp (pretty much the same
as compressor discharge temp) of 300F and the ambient temp is 100F
and you see the temp drop to 200F under boost your intercooler is 50% efficient.
Frankly any intercooler that isn't 80% efficient should be redesigned or replaced with a larger core.
Now here's the neat thing, calculation of a turbocharger-interooler installation's efficiency is taking the turbo's efficiency percentage(which can be calculated fairly easily from observed temps) and dividing it by the
efficiency percentage of the intercooler.
Under some interesting circumsances and setups you can actually have a system with an overall efficiency of greater than 100%
Remember we are talking efficiency compared to a theoretical norm, so 100% is equal to what would happen if... say for example... a bored and cooperative deity cupped his hands and squeezed the air....
That results in a predictable ammount of temperature rise
IF you create a situation where there is LESS temperature
rise you have exceeded 100%.
Now imagine a situation where instead of using AIR as a cooling media you are using water...so the charge air cooler is cooled with water and that water is circulated elsewhere to be cooled off... with sufficient water in circulation for a limited time you can have a system efficiency significantly exceeding 100% (remember that water has 670 times the density of air)and if you start off with chilled water you essentially have "stored cold" in the
water.
"But the water heats up!" you say?
Ok how about this, you have a 5gallon water tank somewhere
in the vehicle and a circulation pump to pump the water from
the tank, to the intercooler, then to a "radiator" to disappate the
heat into the ambient air, then back to the tank.
Remember that you are only putting heat into the water when you are actually "under boost", and all the rest of the time yyou are driving
you are circulating that water through the radiator and cooling it
to ambient.
It's a game of time against thermal mass and only a limited duty cycle...
If I've given anyone any evil ideas then I've done my job for the day:)
For my personal (still being planned) turboRanger project
I have a 1993 4x4 supercab (currently a terminally ill 3.0)
I've been considering the Volvo intercooler (I already have one)
BUT since I want to build my turbo ranger by swapping my
cab and bed onto a Gen4 rolling frame and building the truck
with some sort of AWD Transfer case (still working that out)
In the 1993-94 body onto the '98-up frame I've noticed that the later Gen3 and gen4 trucks have a deeper radiator that extends down past the radiator support and that gave me an evil idea...
I'm planning on using an early explorer radiator tokeep my 2.3T cool and that leave that space under the radiator empty...
and it looks almost the right size to use a Thunderbird
Supercoupe Intercooler.... mounted crosswise under
the radiator (Yeah, I've aleady got the S/C intercooler)
No it isn't a sophisticated Air-water-air charge air
cooling system... but condiering how I want to use
this Ranger, as a highway cruiser, I don't really need more.
AD
