i havea96 ranger with a 4.0l v6 and i put an intake kit on it and now when i stomp on the gas it back fires what wrong and it did not do this when the stock intake was on ????
But what would happen if i put a bigger exhaust on it to help the engine breath more??????![]()
oh okay and is there anything to fix that problem and what do you think about this setup on ebay ???
http://cgi.ebay.com/ebaymotors/B4000-EXPLORER-RANGER-AIR-INTAKE-V6-4-0-OHV-1996-2000-I_W0QQcmdZViewItemQQhashZitem56352dd381QQitemZ370259383169QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Did you somehow change how much air the pistons pull in? Unless you address That as in More CI the engine is Incapable of pulling more air in. Bigger exhaust/intake means beans unless you are acutally going to change how much air the actual engine pulls in.
example. you are pulling down 4 liters of air to be mixed with gas. so you have increased the size of the intake but the amount of air the engine pulls stll equals 4 liters.
exact same is true for the exhaust you still only output 4 liters.
Turbo's and superchargers address more air for the engine without changing the size of the engine. by compressing the air. Cold air intake aftermarket kits are cute. but they are mostly designed to separate you from your money.
Not exactly, there is such a thing as volumetric efficiency, how much air is being drawn in VS actual displacement. Most N/A engines are around 75-85% VE. The original 3.0 SHO Taurus had a special intake manifold that I've been told was capable of 114% VE.example. you are pulling down 4 liters of air to be mixed with gas. so you have increased the size of the intake but the amount of air the engine pulls stll equals 4 liters.
