Thursday night, we spent a lot of time making sure things were connected and hooked up. Then made sure things were out of the way of moving parts... Applied power, and nothing arced or sparked. So, we tried to crank it over. Spun on the first try. So, we kept cranking. And cranking... Checked for spark, had it. Pulled the hose off the inlet to the fuel filter and it sprayed when cranking. But, still no run. Yesterday, we put in a new filter (we hadn't chnaged it in almost 5 years of owning it...). And tried it again.
Cranked and cranked. Then it caught but won't stay running. A few more times, and it ran. First breathe of life from it in 9 months... We didn't try and drive it as the clutch needs fluid and to be bled, but also because we haven't moved the hardlines for the front brakes, or installed the new longer hoses either. Much less added fluid or bled them.
Get that done, tie up some last details, install and modify the inner fenders, reinstall the fenders, install the headlights and I think we are about ready for registration and safety inspection... Then swap the 31s off dor the 35s in the garage. (that might lead to thoughts of gear changes, currently we roll with 4.10s, and I imagine 4.88s would be better...)
There is light at the end of this tunnel. We even moved the Ranger out of the garage last night for a little BBQ with my local club...
