I need help finding some wires
mattr87
roy, washington
I have an 89 2.3t swap that I'm finishing up and i decided to go with the Detail Zone harness and I need to find exactly where to hook up the Fuel Pump power wire, Check engine light wires, Water temp and Oil pressure gauges. I figured that some of those wires are in the plug that is by the ecu under the dash but I'm not sure which ones are which. so if anyone has a schematic that shows that. it would help. Also do i need to run an alternator exciter wire?
