shad
- Feb 19, 2013
- Automatic
I am having some shorting issues on the MAP, O2, TPS, ACT, and the ECT. All are connected by a common gray/red wire. All have continuity to ground. When I disconnect the wiring harness from the PCM, the sensors no longer have continuity to ground. Is the PCM bad? The return wire for these sensors in pin 46. I need to know where it comes out and where does it go?
Thanks!
Shad
Thanks!
Shad
