Hub Replacement on a TTB D28
SlowRanger
Firefighter
EMT / Paramedic
MD Western Shore
Trying to buy replacement hubs, specfically Mile Markers, but on the James Oakes Store and others, I am redirected to the Hubs for the D35. The date range listed for the D28 is in the early 90s, but mines a 95. Just wanna make sure im squared away before buying. Thanks for you help in advance.
The axle on your '95 is probably the so-called D28/35 hybrid axle (found mostly on '93-'97 4-cyl models, and occasionally on 3.0L ones)... This axle is the same as a regular D35 in all aspects except for the differential gear housing and the two inner axle shafts that enter into the housing. So indeed the hubs you need would be the same as for a D35. :icon_thumby:
Much obliged, now I can get my 4wd fixed before SNOWMAGEDDON 16. Thanks again for your help!
