ElleShooTiger
- Jun 30, 2009
- Automatic
The front bushing on my RR leaf spring has collapsed and is causing the spring to rub against its perch and making a lot of noise on bumps.
I've found the Energy Suspension poly bushings, as well as the regular rubber Moog bushings. But whats the easiest way to remove the old ones? They have 250k on them but its a southern truck, so no rust!
Besides pressing them out, can you turn them out using its own bolt and a wrench? I'd like to not have to remove the springs to do this.
