How do you tell if you got the defective valve stems?
OilPatch197
Six million tire valve stems recalled; some safety advocates says problem is much wider and deeper.
Tech International Inc., a Johnstown, Ohio-based importer of tire valve stems,and distributor of tires patches and other tire repair materials is voluntarily recalling 6 million TR413 valve stems made by Chinese company Shanghai Baolong Industries Co. Ltd. between July and November 2006.
Anyone know how do you tell if the valve stems are defective? :dunno: The Tire shop has no clue.
Well, if it's not leaking I don't see what the problem is. If you have noticed that you have been filling up your tires way too often.... take some soapy water and pour a little all over the stem. If there are bubbles.... you gotta leak. I dont think there is really no way to "truly" tell if a stem is bad. I'd look for leaks and dry rotting rubber.
If you are worried about it, they cost about 2 bucks apiece, and you can have all four changed out for less than 20 bucks, probably less than ten.
AJ
