i just did it in my 98 to replace the blend door, hell of alot of work. i kinda jsut removed screws untill it came out.first remove neg battery cable so u dont drain it with teh dome light and jsut a little safety measure, then the trim pieces and "oh shit" handles on both sides, kick panelsand radio bezel helps for handholds. 2 bolts by fusebox on Driver side, one on pass by the kick panel. remove defrost trim 2 gold bolts abover steering wheel, 1 black one on pass side. now heres a tip i found out the hard way, the shifter cable attaches to the stering column via a little white plastic piece, TAKE IT OFF BEFORE LOWERING STEERIN COLUMN or it will break. and it a PITA to fix.you have to remove the hood popper to take off the panel under the steering column, hten take off the metal panel behind that, take plastic shroud off steering wheel, take the 4 botls off steering column to drop that. in engine compartment disconnect the 3 big electric plugs, easiest to take off the main fus box there too, so u got mroe room to work. you may have to take like the shifter off the steering column for soem wiggle room. also take e-brake release off. it woulda helped me to label all the screws as i ended up with maybe 4-5 screws that i forgot where they went. i also took out eh driver seat for soem extra room. hope it helps a little i didnt have much help and it turned out fine. took me maybe 6-7 hrs total to remove fix and re-install everything. good luck and godspeed man.
