how big of a list is a cut and turn?
nooch450
New Jersey
I was wondering when you get your beams cut and turned, how much does the frame on the truck rise from the ground? Assuming you put the propper springs to level the front end out for the new beam angle.
PS on a 4x4 ranger 1991
pretty sure if you get 4in cut and turned beams then you basically have a 4in lift with the correct coils.
Well that's great to hear! Can anybody confirm this?
It is true...
My previous cut and turn setup was for 4". You can do a lower ball joint extension and a pie cut further in on the beam and achieve a lot more lift..
