Horsepower out of a 3.0?
Where E fans are concerned....How does one go about installing the needed wiring for the sake of A/C?
When one engages the A/C on a factory equipped vehicle the PCM controls the fan/fans, the fan would be engaged when motionless or at low speed but when the vehicle begins to move fast enough the PCM disengages the fans because they are no longer needed. The PCM in this this truck does not have that capability.
I've considered this myself for the same reason (minor HP gain & and to not hear the annoying wind/drone at start up) but haven't got around this hurdle.
The most common method of control for an e-fan on a vehicle that didn't come with one originally is buying a separate controller and temp probe. The temp probe is inserted so that it can record the coolant temp, and the fan is triggered on/off when the coolant temp dictates it. You could also incorporate a manual switch, or nearly any other control method depending on your electrical skillset. If you want the e-fan running when A/C is on, I'm sure it would be possible to wire it up so that the e-fan comes on anytime the HVAC controls are in the "A/C" position. You'd really have to do a ton of idling with the AC on for it to be worth it though.
I have mine currently setup to only run when the the A/C compressor clutch is engaged. A relay kicks the fan on and is activated by the power wire going to the A/C compressor. I did this as a temp measure 2 years ago when my fan controller failed and it's worked so well I haven't bought another controller. (when in stop and go traffic, I have to put it on defrost or A/C to make sure the temp gauge doesn't start to creep up) When it's hot out, I'm running the A/C anyway, so the fan is running and the engine is staying nice and cool.
You want an E-fan to kick on with the A/C so the condenser doesn't get too hot and fubar the system.
Another benefit of the e-fan is noise. One doesn't realize how much noise the stock fan makes until it's gone. The truck is much quieter at speeds below 35-40mph.
Cooling isn't an issue. The fan on my truck pulls 1600cfm and keeps the truck plenty cool, even when towing 3k+ lbs in 100+ degree heat.
If you are building an automotive electrical system from scratch you would of course include an e-fan on with AC circuit, and also wouldn't install a condenser e-fan
But why would you want e-fan to come on with AC?
Because engine load is increased and condenser in front of radiator will heat up with AC compressor on.
If converting mechanical fan vehicle to e-fan the condenser will already have it's own e-fan if needed, if it doesn't then mechanical fan was fine.
Mechanical fan clutch is operated by Radiator heat, not engine heat, it engages fan more as the center of the radiator heats up, so will always be behind actual engine temp.
Nothing at all wrong with that, just pointing it out.
Converting to e-fan allows you temp control and manual on/off as you see fit.
If you do mudding and/or water crossings having an e-fan OFF switch is great, lol, engine bay stays alot cleaner, and drier.
Ron:
as stated ( for my personal purposes) to kill the howl that the fan gives off when the engine first fires up, after approx 10 secs the fan noise begins.
For the A/C one needs the fan engaged when the vehicle is motionless or moving slowly, but the fan is not needed when the vehicle is at speed to cool the condenser.
What I am looking for is a controller that can intercept the vehicles speed so as to disengage the fan when it's not necessary to spin.
