- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Manual
- Total Lift
- 6
- Tire Size
- 35"
Drove the '90 to work today and it'd been a while since it's been on the highway, I do remember it being somewhat noisy in 5th for a while but not that bad... sounds like gear backlash or something when under load, silent in the rest of the gears (didn't go into reverse yet today so not sure there...). Any likely cause of the noise? Just worn out? It wouldn't be something dumb like the big nut on the output shaft backing off would it?
This transmission has somewhere north of 200k on it, we rebuilt it (bearings and synchros and one slider that had wear) when I did the lift around 11 years ago but it only has 20k miles or so on it...
The transmission is a '89, I know there were some changes over the years like one of the sliders having more or less teeth in I wanna say '92, but if I were to pick up a spare transmission, any years better than others? I don't remember... Going to try to pick up a 2.3L 4x2 trans because they were most common, swapping to my 4x4 stuff doesn't scare me, I kinda remember getting in there, don't remember it being all that bad...
Edit: The noise is kinda a rattle, with no carpet or insulation on the floor it really resonates through the cab... doesn't sound chunky like a gear, more like something is loose and has play... kinda like idle in low range first gear rattling with all the gear lash stacked up except for it's happening at almost 4000rpm output shaft speed...
