Millster
- Jun 19, 2009
For a long time, my truck has had a very vexing issue. It will start on the first crank almost every time (even after sitting for months) and run great... until it gets warm. And we're not talking engine warm, we're talking about ambient temperature warm. The engine can come up to temp and it'll run fine. On cold days, I can go almost 20 miles before I start having problems. Warm days, sometimes it will die just sitting in the driveway.
In any case, the symptoms right before it dies are consistent with running out of fuel and to add to that, after it has died the fuel pumps will not run. If I let it sit for about 15 minutes without trying to start it, it'll take a few cranks to get a prime and then fire right up.
Someone on here mentioned problems with the fuel pump relay. Well, I had replaced mine not too long ago so I figured that was not the issue. BUT, that relay is tied to the ECU relay. The wheels in my head started turning. I finally got a chance to take a look yesterday and sure enough, my ECU relay is hot enough after about 10 minutes of running that it's uncomfortable to put your hand on. Wrapping it up and letting it get really warm makes the engine start to run weird. Give it a little tap with the end of a wrench and the engine will stutter and then clearly go through re-reading the sensors to get the mixture right before settling back into idle. Tap it hard enough and the engine dies.
Looks like I found my problem. And to think... it's only been essentially off the road for 6 years.
