High School Project Poll
alpinestar
Vancouver, Wa
I'm doing my Junior/Senior Project on the different suspension types such as eliptical, 4 link, 3 link, leaf sprung, so on and so fourth. im gonna write up a couple questions, just answer them PLZ and i will add up all the answers. im sure over the next few days i will come up with more questions. for now:
1.What are you currently running on your 4x4?
2.What is your favorite or what do you plan to change yours to?
3.What did your 4x4 come with stock?
i will answer them as well.
1. Leaf sprung front and rear.
2. 3 link with XJ coils
3. TTB front, leafs rear. obviously...
thanks guys!
1.What are you currently running on your 4x4? 3-link front - Leaf sprung rear.
2.What do you plan to change yours to? Triangulated 4-link rear
3.What did your 4x4 come with stock? Double Wishbone (Short/Long Arm) IFS - Leaf Sprung Rear
TTB: Skyjacker 6" coils/extended radius arms/drop brackets, skyjacker 6" leafs with 2.5" blocks
EB D44 solid axle, EB springs, stock fullsize radius arms. Belltech 6400 shackles in rear
5" suspension, 63" chevy rear springs, extended shackles
79 F250 D44 narrowed, 3 link w/ air shocks, 63" chevy rear springs and ext shackle
Twin Traction Beam w/Skyjacker XJ coils front, bastardized Explorer leaf springs rear
The TTB suspension seems to work quite well for me... The front may end up as a monobeam (straight axle) setup if I ever upgrade to a bigger size axle (D60) to handle bigger tires. It would most likely stay coils/ext. radius arms however (to keep things simple). I may do some sort of a 3 or 4-link w/coils on the rear eventually, eliminating the obnoxious leafspring shackles on the rear (this would hopefully get rid of some wheelhop issues in the process).
TTB front, Leaf springs rear
63" 1/2 ton Chebbys in the rear with a 6" block and extended shackles
52" 3/4 ton Chebbys (with 3 leaves pulled) in the front and extended shackles
I like the leaves minus the road handling, maybe air shocks down the road but the leaves are fine.
Torsion bar IFS front and stock ranger leaves w/ a 2" block in the rear.
1.
3 link front half ton coils. half ton leaf rears
2.
4 link rear. different springs...not quite sure of what i want.
3. stock 2wd ranger junk
1.Ttb frnt and leafs in the rear
2.plan to do a sas with 35's and add a leafs in the rear
3.stock ttb and leafs
1. 4in rancho w/ttb, chevy leafs/2in shackles
2. d44 w/ Triangulated 4link, 9in rear with leafs
3. d35 ttb and leafs
1) Explorer d35 and 8.8 (converted to spring over) 5.5" superlift drop brackets, skyjacker 6" coils, rear: fr-34 leafs "4in skyjacker" and belltech 6400s
2) SAS dana 60 kingpin and a 14FF rear or a fullwidth d44 and 9in rear
3)stock ttb d35 7.5 rear
1.) TTB front, leaves rear, stock height, fornt sway bar removed
2.) Cut and turned beams up front, lift coils, extended shackles rear ~ 3" lift, quick discos for sway bar, correct travel shocks, limiting straps. Try to keep CoG low!
3.) TTB/leaves
