sean3481
- May 19, 2009
There is a steady flow of coolant that is pouring down from near my water pump, although i don't believe it is the water pump or the gasket. I'm unable to see the exact leak it seems to be dripping down the passenger side, just above it. I just replaced the intake manifold gaskets and head gaskets, which didn't fix the problem. The leak drips coolant whether the vehicle is on or off, and there sounds to be a lot of pressurized air that is is also coming from the leak spot, but like i said, I'm having a difficult time pin pointing exactly where it is coming from. Any ideas?
Thanks
Thanks
