Poweranger2
I have a 91 4x4 4.0 v6 ranger with a 5 speed and the transmission is no good and i cant find another one to put in the truck so could another 5 speed trans out a another ranger would work and what i would need to change
You have to have a 4.0 trans. Or in theory a 2.8/2.9 trans but that would require work and youll be getting a weaker trans.I have a 91 4x4 4.0 v6 ranger with a 5 speed and the transmission is no good and i cant find another one to put in the truck so could another 5 speed trans out a another ranger would work and what i would need to change
When i said weaker i was reffering to a TK or mitsu trans.Ok…
So the 91 4.0 is an M5OD trans…
you can get another trans and swap the guts in, but the 4.0 was unique in that it has its own gear ratio set.
The 2.3 (single and dual cam), 2.5, 2.9, and 3.0 versions of the M5OD all shared the same ratio set, so, you’re not getting a weaker trans per say, just a ratio set that is t gonna be very well received behind your 4.0.
The 2.9 and 4.0 share that same bellhousing pattern, even though they don’t look the same and have different ratios.
I do, however, have 2 4.0 transmissions I’m not using… and I live in Alabama
So, I could always build you one…
PM me if you need…
Which is why i said swapping to a 2.8 or 2.9 trans would be a downgradeThe TK and Mitsu were never behind the 4.0.
Yes I know they fit, but….
No i havent had a chance to look into it. Im not sure how to even figure it out. Even if it would being a ford product im sure the part numbers are different lol.I know, and I wasn’t being a jack wagon, I was just trying to give him a fuller answer to his question.
You ever figure out if the 3.0 dipstick tube would fit? If not, I can get you one from a friend.
I wasnt tryin to be an ass either
Ok....its not a huge deal.
No offense taken. If you need a rough measurement, I can get you one in a few hours.
