Help with swapping 2007 Taurus dual fan into 1996 B3000?
Linus72
Orange, va
Ok so I'm trying to put a efan setup into my 96 B3000.
Both have the 3.0 motor and roughly have the same size radiator.
Easy enough to remove the taurus' fans plus shroud and install into the B3000.
But, how to provide it with the necessary relays, temp switch etc?
Should I just hook up a aftermarket temp sensor efan kit?
Or, can I utilize the stuff from the donor Taurus?
The taurus' has blown motor but many parts I could probably use for the 96 B3000 3.0?
Thanks for any help!
