Help, failed Referee smog check for year swap!
IT WORKS!!! Turn the key to crank the engine and the 'check engine' light comes on....then it goes off when the engine is running and key is returned to the 'run' position!!! Thanks for all the help guys! :)
Now I gotta go run it all clean under the dash and solder it into the main harness instead of just twisting two wires together and hangin it out the window and to the connecter under the hood...LOL.
Failed my second referee smog test, but this time only for still slightly too high HC on low speed test. Everything else was good. Need to replace my catalyst and try again.
Forgot to update....PASSED with a new catalyst. Thanks to all who helped!!! :)
