Help engine change. 2004 4.0 2006 4.0
I have an 04 ranger with a vin engine code E and I have a 2006 4.0 Vin code F I want to put the 06 engine into the 04 can anyone tell me if i can do this and what are the differences between the two
Something must have been misread.
2006 code F is :F 5.9 I-6 Diesel Cummins 230/520
That's a medium duty truck option.
Just for reference 2004 code F is: 7.3L Turbo V-8 Diesel Navistar 250 - 275
for light trucks or the same 5.9 for medium duty.
This is the vin on my 04 # 1FTZR45E84PA39103
The 06 vin
1FTZR45F06PA36943
The 04 is thitle 04 but the door says it was built in late 03. Any help is appreciated
When the label was printed the E's lower line was missing, if possible look at the metal plate in lower drivers side corner of windshield
Both are "R45", Ranger super cab 4x4 4door(5th, 6th and 7th digits)
Only 2 engines were offered in 2006 Ranger 4x4s, 3.0l OHV and 4.0l SOHC
VIN is E for 4.0l SOHC, 8th digit
VIN is U or V for 3.0l
So misprint, you will be fine with the swap
I appreciate your knowledge. Every junk yard I asked give me a different answer and all said it wouldn't swap one even told me it had to.be an 04 engine but looking at the 2 engines I couldn't see a difference considering I have an 06 engine with 80,000 miles I didn't want to buy a junk yard engine thanks again
the injectors and ecm and fuel system change up somewhere between 03 and 05... 07 we just swap the entire induction and have got away with it...as far as i know. there are differences.....the heads change...like they did with the ohv.
