Hellwig 550 EZ helper springs on 2010-11 with rear discs
Danno1985
MKE, WI
2.3 (4 Cylinder)
stock
Total Drop
stock
stock
I put a fiberglass cap on my 2011 XLT for the winter and almost immediately noticed the back sagging a bit, so in addition to looking at some new coils for the front to level out the "Ranger lean", I'm looking into refreshing the rear suspension a bit as well. I've had great luck with Hellwig products in the past on my older Toyota trucks, so I thought the Hellwigs might be good in this application as well. Hellwig's site claims the 550 EZ springs fit up through 2011 model year, but after reading a review from someone with a 2011 claiming they didn't fit on their rear disc brake-equipped truck, I wanted to see if anyone here has tried them and has any additional info to share. Just to reiterate, mine is a 2011 with rear discs, which I believe started in 2010 with the advent of "Advancetrac". According to the reviewer, the issue was with the brake bleeder valves interfering.
Why would helper springs not fit? They go over or under the leafs, right? The disks arent hitting the leafs so i dont know how tha would make a difference?
Yeah, I took a look at mine today and can't see how they wouldn't fit, but according to the review claiming they didn't, there was an issue with the u-bolts hitting brake components. This isn't an add-a-leaf, just so we're clear:
I said screw it and ordered the kit, so I guess I'll find out.
