Hello every one!
mqknguyen
I just bought a 1993 Ranger super cab XLT, V6-4.0L.
It needs a lot of work done though.
* Oil leak.
* Water leak into cab from backside ->back side of head board wet when it’s rain.
* ABS & Check Oil light on.
* Parking brake does not work.
* Cracked windshield window.
I need all of you help to bring it up.
Thanks in advance to every one.
MQ
check and fill the oil and your oil light will dissappear. the abs light is probably a bad abs sensor or a short in the wiring, the sensor is located on top of the rear axle. the oil leak can be easier to find by adding a dye made specifically for tracing leaks (google tracerline products). for the parking brake, check that the cables that run under the cab on the drivers side have some tension on them. if not they may not be hooked up (cut most likely) or may just need cable adjustment. as for the window leak and cracked windshield, you may need to make an appointment with a glass shop or try your hand at the junkyard.
