Having trouble removing i beams
Kingman
KS
I've had a set of DJM dream beam installed and am having a bit of hassle removing them. I've removed the balljoint nuts, steering linking nuts, but the brake assembly doesn't want to budge. It seems as theres a spacer/collar thing up against the top of the upper bailljoint holding it in, it went above the balljoing on. I've read this is the camber adjuster and it should be able to be pryed off, I've taked a 3" long pry bar to it and nothing budged. Any ideas. The beams have only been on a few years. Thanks all!
