ForgedCrank
- May 30, 2024
- Indianapolis, IN
- 2.3 (4 Cylinder)
I know this is an oddball topic but was hoping someone might have experience in this arena. Hope this is the right sub since it's engine related, just not specific to an engine.
Anyway, due to the number of vehicles I have, most of them sit for long periods of time. When I do go to start one of them up, I spend a ridiculous amount of time having to prep by finding the right fuse, disabling the fuel and cranking the thing for oil pressure... putting way too much load on the starter, etc. all in an effort to pre-oil the mains and cam etc. before startup.
So anyway, my idea was to investigate using an oil accumulator, but just for startup. I figured if I could set one up with a low pre-charge pressure that is well below operating oil pressure, that would do a nice pre-oil of the engine oiling system before startup. But, the ones I am looking at are completely mechanical in nature, meaning that when the engine operating oil pressure drops below your pre-charge PSI, oil will be forced out of the accumulator into the engine oiling system. Then, when oil pressure goes higher than the pre-charge pressure, oil will pump back into the reservoir until full... and the cycle continually loops. One thing I don't understand is how this system can be used to HOLD a full reservoir of oil when the engine is shut off (saving for the next startup), and then how to release that oil to pre-charge the oiling system prior to crank.
There is a piece in this I am missing somewhere, or I'm just trying to use this for an application for which is is not intended, I'm not entirely sure.
These appear to be generally used for racing and off road applications for when the sump might end up dry momentarily during operation. This obviously isn't my main goal, mine is just for startup oiling. Something with a 12v pump would probably be more appropriate for my application here, but I can't find anything like that.
Do any of you have any experience with these things, or experience in doing what I'm attempting here? Any advice?
