- Oct 7, 2009
- Automatic
On the "86 2wd Ranger, as the gas line leaves the gas tank, the 1st fixture it passes through on its way to the engine, is a canister that the return gas vent line also passes through. I realize that as long as the low psi pump inside the tank is keeping this canister full, the high psi pump (next up on the line), will always have a supply of fuel readily available, and then either pump can work without resistance from the other. At this point, I am assuming that I understand the principle of the canister. At any rate, it has two valves w/ springs and caps (plugs) that must work with various pressures. In my case, one can see that the springs are turned sideways in thier cartriges, and the plugs are just kind of floating around in the cartriges. I noticed the prob. when I was looking for a reason that my rig was stumbling or dying, mainly just feather footing around town, or when sitting at a stop. When I pulled my gas tank (my rig only has 1), and found that my inner pump was shot, I thought I would also ck. out the cannister, and do what maint. I could on it. One source said to use it as it is, and see what happens. Another said to remove the valves, and skip the thought of them possibly adding to more problems later. The last source said to by-pass the canister all together, just joining the fuel lines together. Direction ?
