Front lift help
brandothehick
Colorado
96 mazda b4000 Front lift help
i have a 96 mazda b4000 4x4 and my front is 4in lower then my back. what is the best (cheap) way to lift the front to even it out, and so i can put 33' or so tires on it. Would it be ok for me to just put front coil springs on that are 3in higher, or just 2in rubber spring lifters, or do i need to just go with a full leveling kit?
I would try spacers(washers under the coils)1st.if you go higher than 1 1/2-2 in. you will need drop brackets or you cant properly align it
