I had a few issues accumulating but had been holding off till I had the funds to get everything done at once to economize on the labor as I was having a shop do this.
Due to collapsed brake line that caused caliper to stay engaged the driver front had gotten severely overheated and smoked the grease and actually melted the center plastic knob on the locking hub. Not related to that I also had vibration starting around 35mph when hubs were locked (4WD on or off) including metallic dings and other not good sounding things.
So got the differential checked out, it seemed okay, changed fluid, nothing metallic in the diff fluid so am assuming nothing major there.
The wheel bearings on both sides replaced, rotors replaced and U-joints replaced. One of the u-joints was really bad and the one bearing on the passenger side used for the 4WD drive was also bad. Also put on a new set of warn locking hubs.
After all the work things are much improved. Most of the nasty noises are gone but there is a vibration that can be heard and felt that gets quite noticeable up around 50 mph.
I looked at the right side shaft between differential and wheel cause I seen people saying that phasing needs to be correct. The phasing definitely is not correct. Now having discussed with the shop they said it shouldn't make a difference and pointed to the small amount of movement the front drive shaft has where it comes out of the transfer case. A concern I had expressed to them in the first place.
So my question, with the side shaft phasing wrong, just how severe does the vibration get? Is that probably all I am experiencing? My inclination is that it needs to be taken care of anyway. the vibration doesn't seem related to the right side per se if that is also an indicator.
Second question is how much movement is acceptable where the front drive shaft connects tot he transfer case. The kind of movement I mean is if you push or pull the shaft perpendicular to its axis. Concern is that transfer case output bearing may be bad or splines are too worn.
Last question, referring back to the right side shaft, is balance a potential issue?
