lestercheetah
need help! my housing (aluminum differential pig) is cracked and i need to switch gears over to another housing, everything has been removed except the inner pinion bearing race and oil baffle and i need to know how to remove these without damaging the oil baffle for i plan on reinstalling it in the other housing. i have new bearings and races and seals for this assembly and a collapsible spacer and pinion nut + the other housing. all i have at the moment to remove these are a hammer and punch but i will damage the baffle doing it this way, i cant get a good grip with my cheap slide hammer and my 13 pounder is a little to big....i need advice....thanks to those in the forums, i read them quite often an they keep my 1991 ranger xlt 4x4 running.
