Front coil advice
Deffinately go with some extended arms. Without longer RA's you're simply maxing out the pivot bushings and you won't get the full effect of the ZJ coils. Having to compress the spring to get it in will mean that you'll be changing your pivot bushings much more frequently. It's similar to riding a bike with the seat far too low. Your legs never fully extend as they would if the seat was higher. Long soft travel from these coils should be similar to what Todd sees with his rig.
Thanks for your advice guys. I'll keep the F-150 coils in awhile longer. They work well enough on-road and flex reasonably well. I'll keep the Jeep coils I bought and swap them in during the next stage of my buildup, when I'll be doing a 302 swap, along with a new body and some James Duff radius arms.
