88mudder, unless they have drastically changed the flex fans from years ago, the fan should only thin out as the rpms increase, IE flex. At low rpm (and at rest) the curve of the fan is most dramatic, if it clears everything when turned by hand it should be fine at idle, and at high revs the blades flex to decrease drag, ie decrease parasitic loss. The only reason that it would make contact is if it the pump shaft is bent or ocsillates due to bad pump bearings, etc.......![]()
At least thats the way the used to work.......![]()
Or...you have a flex fan that's supposed to be spinning the other way. Not all water pumps spin the same direction. The fan blades would get more angle as the rpm increased. I've seen it happen.
