- Mar 24, 2013
- Age
- 81
- Renton, WA
- 02 2X4; 08 FX4
- Automatic
Another weird idle problem!! - 2002, 4L, 2WD, auto, about 85K miles. No codes, none. Drives great.
This happens only on the first start of the day. It starts right up (like it always has); but, idles at about 750/800 rpm. Not the “normal” 1500 rpm. If you put it in drive or reverse it holds the 750/800 rpm. If you manually raise the idle to 1500 or 1600 it holds at 1500 (1200 in drive) until the ECU drops it as it warms up. This problem started out being intermittent. Did it sometimes; but, worked normal most of the time. It now has the first start low idle all the time.
Every start after the first start (at least for 4 to 8 hours), it goes to 1500 and holds until the sensors/ECU lowers it to somewhere between 750 and 1100 rpm, depending on engine temperature.
When it warms up it idles at around 750 rpm. When you shift from drive or reverse to neutral or park you get a momentary drop (a dip) to about 650/700 rpm and it them returns to 750.
I did replace the IAC (Napa) about 4 months ago for another problem (low idle when warm in neutral or park). The new IAC didn’t immediately to fix that problem (but, for some unknown reason, over time that has healed itself???) except for the dip in idle between drive and park. If you pull the IAC connector (when warm), it stumbles, fumbles and stalls. I have looked for vacuum leaks; but, didn't find anything obvious.
Any ideas/help would be appreciated, Ed
