Extended radius arm build
Brett3xx
I'm building a longarm setup for a Friend's 94 mazda b4000. I'm using 2" 0.25" DOM and 1/4" plate to extend the stock radius arms. The dom and tube adapters are on the way. I'm using 2.5" rough country flex joints at the frame mount. I've already built the radiusarm mount brackets, but still need to finish welding them up. The Trans crossmember will be 1 3/4" hrew that will tie the radius arm brackets together. I'm open to ideas and suggestions.
This was the original idea, but has been changed to allow for driveshaft clearance
radius arm brackets
Brett, great looking brackets....can you reply here or send me the measurements/demensions for the brackets you made? I would really appreciate it. thanks....dale
c130marine@yahoo.com
Wow, nice job! How do they run?
