91rangerxlt
Ive got an o2 ranger edge with the 4.o, was wandering if a tcase and transmissiin from a o1 explorer with the same motor will fit. Im sure it will just wannA be sure before I tear into em.
well, according to the tech library (above link) the 1354's went all the way to 2002. not all explorers were awd (4405) back in 1995-2002 era.
additionally, i believe the sohc engines had a single bolt difference where the bell housing mounts up from the ohv 4.0 engines. that would mean you'd need the new tranny/tc from another sohc 4.0 for the easiest swap.
again, use the tech library here on trs for more information.
both vehicles have tge sohc motor. And the exploder tcase is auto 4wd not awd. So can I get a yes or no answer as to if it wll fit lol.
Like I said. The trans is the 5r55e, yes it will work.
The t-case is a 44-05. It will bolt in, but your electronics will not be able to shift it.
Theres no way its a 13-45. A 13-45 is from a full size, has a 31 spline input and 6 bolt pattern.
If you meant 13-54, then: The only way its a 13-54 is if its a 2 door (sport) or a Sport trac.
simply put.
'01 Explorer:
4 door v6 --- 4405 control trac
4 door v8 --- 4404 AWD
2 door v6 --- 13-54 (same as sport trac)
2 door v8 --- doesnt exist in stock form
i just checked the tech library... Yes it says that the 13-54 was available in the Ex between 95 and 00. Its wrong.
I ment 13 54. Is there any way to get it to work?
