explorer axle swap done
erikm
Solid Axle Swap
Iowa
i went very well.... only question i have is with braking issues..... do you have to swap out to an explorer master cylinder and abs unit to make it correct? it seems to be ok, but have only driven in town since the swap.
Yes, the giudes we have online suggest to take the E-brake as well as the Explorer master cylinder.
Are you getting an ABS light?
I didn't do the master cylinder swap with mine and I have no braking issues. I didn't mess with the abs either... Just make sure it is completely bled and that you have no leaks. It took me a while to get my rear brakes to not leak but I made my own lines and it took a little getting used to making flares. If you have already bled your brakes make sure you didn't forget to do the front ones too.
