Picked up a very used 91 Explorer Sport 4x4 with 5 speed today. Grinds going into 2nd up shifting and down shifting. not bad but annoying. Could this be a synchronizer?
If its only in second gear then yup the syncro ring is worn out, if it grinds in other gears then a worn dragging clutch, if you time your shift and throttle just right you can get a lot less grind and more useable time out of it
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
