Excluder Seals on a 2001 4x4
MRanger
United States
2001 B3000 4x4
My truck is making a VERY annoying squealing noise from the front. It sort of sounds like brake squeal but it happens mostly between 15-30mph and turning the truck makes the noise worse/more frequent. After doing some searching I think it might be the excluder seal(s). I found a TSB on them and it appears the updated part is YL2Z-3K070-AA, however that part appears to be discontinued. After more searching it appears duralast 710519 or National 710519 might be a correct substitute. Can anyone advise? Are these seals even necessary for a truck that doesn't go into mud? And if they aren't, can I just remove them and run without them? Thanks for your help
