Evaporator purge valve hose question
Burnsy
Hudson fl
2001 ranger 3.0 v6 flex.......the hose that goes from the valve to the throttle body is getting weak and crustyish...i want to replace it.....can I get just that hose? And if so, theres some type of flat looking connector in the middle of the hose...so I guess its actually two small hoses joined with this spacer/connector...? I didn't examine closely but the flat connector doesn't look like air would pass thru it but I assume it HAS to.........does all that come as one piece? When I search online I don't seem to see the exact match as my hose, or maybe I'm just not seeing things right........why do they have that spacer/connector in there???......from the nipple on the throttle body the hose comes out about 4 inches then turns 90degrees toward the windshield for another 4-5 inches , then a connector, a little more hose, then another 90 in toward the canister, and there may be another connector in the last run I can't remember, but that's it....and it may connect with an elbow at the valve...I only had a minute to look at it, it got dark...I left the truck at work , took the work truck home........can I buy the hose just like that how I mentioned it ? Without any additional stuff? All the related vacuum elbows and small lines are fine....I suppose I could go to auto parts store and view the pics etc but thought I'd run it by here first......anyone have a part number ??? Thank you.....ive glt 325k miles on her, bought it with 220k......my previous 2000 ranger I got with 60k on it and sold it with 525k miles, did every oil change and NEVER let it overheat, guy put a timing chain and new rear end in it, it's still going
