Engine noise after top end rebuild
wayfast73
I just bought a 2000 ranger, the previous owner put brand new heads on it, and I assembled the intake. I ran it today it runs great I have good oil pressure, it revs right up to rev limiter at idle, no CEL's, no smoke, and it made enough power to chirp second gear and pulls well (5 speed). It has a knocking comming from the drivers side that is consistant with rpms. I dont think its a rod or bearing since theres no power loss and has good oil pressure, but I cant feel a exhaust leak around the manifold. Any known areas these manifolds leak? The EGR tube was tight but since its a knocking it seems like it would be one cylinder or plug. I probably put 2 miles on it after letting it idle for 10 minutes or so.
uh huh
Manifold leaks cause burrnt valves.. Guys with burnt valves sometimes get new heads.. Makes sense that it might be a manifold leak. If it is repair it before you burn another valve.
Rod and bearing knocks don't usually lower the power. So be careful that the noise isn't a rod knock.
Big JIm:hottubfun::wub:
Ill have to check the manifold and rear plug, I was also thinking it could be a colapsed lifter or a rocker that isnt adjusted right.
