Rinny650
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I finally got my engine semi sorted out but for the entire time I have had the truck, once I get maybe 1/8th mile down the road it will start hiccuping and jumping and sputter out and cut off. I cannot figure out why. Any ideas? If you need to know more info just tell me what is needed?
Im not real sure on model or anything else. Its I believe a 350cfm. Its about the smallest they make. It could possibly be a 500cfm but no bigger
I think I may have messed up the float level horribly yesterday messing with it.
Start the vehicle,remove fuelbowl sight plug,observe fuel level.If none seen,too low,if pouring out the hole too high.proper level is level with bottom of hole with engine idling.
To adjust,shut down engine.
Loosen lock screw on top of bowl just enough to allow for turning adjusting nut.
Using 5/8" wrench turn adjusting nut clockwise to raise fuel level,counterclockwise to lower.
Use increments of 1/4 turn.
Retighten lock screw,restart engine and check level.
Taken from instructions that came with my holley 0-7448 350 cfm carb.
here is a neat site for calculating jets-http://bgsoflex.com/auto.html
