http://flashoffroad.com/electrical/Batteries/BatteryDrain.html
^ I'll refer to that link in this reply.
So, the dome light is on.
Roll the dash lights dimmer knob off its fully up detent and shut it off. Exercize that switch function (roll it past full bright) a few times, make sure it works.
Nothing in your symptoms makes me think your GEM is faulty.
Bumpy road, flickering lights, alternator charging issue, no GEM connections at all.
Most likely have a bad cable, one of the big ones to either the battery, alternator or ground. Is your battery properly secured to the tray?
Seriously.
The battery saver and accessory delay relays in the relay box SHOULD be hot, until they time out (that IS a GEM function) and de-energize. The interior lights relay will be the third one in that box. It'll be hot too if the dome lights are on.
So, back to the parasitic draw test.
Read that link and it explains that you have to connect the meter AFTER all those timers time out yet without letting the connection break so that they reset. IMHO, forget doing all that and do this:
Open the driver door.
Latch the door latch securely as if the door were shut (use a key or screwdriver shank).
Ensure that the Door Ajar light is now OFF.
That's the end of the door ajar and dome light problems while testing (you can do the same for the passenger door if desired. *This is the way we listen to tunes without leaving the dome light on and door dinger going off while the key is on ACC.* If the dome light is still on, I can send you schematics (MY 2000 should be close enough) to help you figure that out.
PM me your e-mail address so I can send those.
Here's what I want you to do, called a wiggle test.
Start and idle, headlights and blower on.
Wiggle Red and Black cables near Bat and along their lengths.
Bang on the Underhood Junction Box with the palm of your hand, vigorously and wiggle all the harneses in its area. Trying to simulate what your bumpy road is doing. Do the same with all the chassis grounds, head to windshield wiper motor especially.
If you keep an ear out for the speed of the blower or have the lights shining on a wall....
You'll find it.
Send me the PM, having the schematics will save you a LOT of frustration chasing your tail.
(< Click on my username, select send PM)
Seriously.
You'll find it.
