EGR Valve goes where?!?
94RangerMike
SC
:shok: So I have several codes coming back from my OBD testing. Everything from bad O2 sensors, front and rear, to EGR valve is about to come to life and kill you(eg. too much flow, not enough flow, open circuit, misfiring in cylinder 4, doesn't like how you drive, etc.)
You think replacing both O2's and the EGR will fix it, or will just open another wound to shove money into?
Can you run without EGR system if you do not live in an Inspection state...on the DL...:dunno:
yes. unplug it and it will stop working
