fatcalvin
- Feb 14, 2009
- 2000 Ranger 2.5
- Automatic
Hey guys. im getting ready to start my V8 swap into my ranger and was hung up on a few things. First off i got a 96 explorer donor with a BAD block( threw a rod). I removed the motor and pulled the stuff i needed off it( Cam and accessories) The block that i have to replace the other block is from a 87 f150. I was told that i had to swap the cams out between the two because of the firing order of the explorer motors.
Heres where my problem lies:
1. I assume that i need to use the distrubitor from the explorer in the f150 block to match the firing order. Correct?
2. I was going to "freshin up" the block with new gaskets/waterpump, oil pump, timing chain and what not. Would i get stuff for a 1987 block or the 96 block. I know the oil pump depending on what style oil pan i run but the waterpumps look the same as far as i can tell.
3.I didnt get the GT40 head from the explorer so i plan on using the heads and intake from the f150 bloakc as they are very similar looking. Would this work with my setup?
Both the blocks were EFI and the f150 block is complete. Thanks in advance
