Duraspark Conversion Coil
TenSeven
Does the coil recommended in the 2.8 Duraspark Conversion article need a ballast resistor?
If you use your factory tfi coil, no you don't need to.
The canister style needs the resistor. The factory one doesn't.
The one in the napa link is the canister type and needs the resistor.
