86_4x4beater
- Aug 18, 2009
anyone got info on the "swap-ability" of a full size dually rear axle onto a gen 1 ranger ? i would NOT run duals if i swap it . i was just thinkin that the dually rear axles have a shorter wms to wms then a regular SRW full size axle . so in theroy it should adapt to a ranger with just moving the spring purches on the drw axle to match to the rangers leafs , depending on total length on the axle .
i just think itd be bad ass to have a d60 or d70 or 14 bolt full floating axle on a ranger that weighs nothing ...... itd be alot harder to break then the stock rbv axle . and i know the drw axles are heavy but i like the strength it would provide and they are only $80 at the local wreckin yard , alot cheeper then having a srw full size axle shorted and moded to fit . any brain storming is welcome . thanks .
