...Driving Me Crazy...
Massachusetts
...Constant vibration while in drive (felt mostly under drivers side seat).., vibration at around 30mph under load.., no vibration when no gas is going to engine... U joints are good.., carrier bearing is stable... There is also a "clunking" noise while in any gear but it goes away after several tire revolutions... Tires are inflated properly... Last balance and alignment was about 2 years ago... I was thinking tires imbalanced... This happened suddenly... Any thoughts? Thanks! I also have video tape of the noise if needed... 96 Ford Ranger V6, 3.0L, 209K miles... Thanks for the help!!
Youtube Video Uploaded:
http://www.youtube.com/watch?v=M6cb5y_54Jw
Bearings? Those suckers fall out of place... lots can get messed up and getting new ones machined is a pain and costly. Have you taken the tires and all that what-not off and looked at the Hubs and stuff?
I have checked the rear drums, shoes, etc... Tires.., it is not the tires... I am suspecting a failing u joint.., but they seem to be ok... But Ima replace all three u's and have the drive shaft rebalanced anyways... Hopefully that works... What sux is that when I was looking for this problem.., I found a minor leaking axle seal.., so yeah.., replace that and the other and replace the rear bearings... Not costly.., just need a tool to get to them (which is costly)... R.I.P. Ford Rangers! they should keep making em...
