Drilled rotors came into existence back when the glue that held the asbestos together tended to form a gas layer between the pad and rotor. As the gas held the pads off the rotor, brakes would "fade" rather dramatically. The solution was to drill the rotors, allowing the gas to flow through the holes and stopping was maintained. It worked on those nice Porsche's so very one wanted them.
But fast forward 3+ decades and the material is no longer asbestos and the glues don't off gas near as much. So, drilled rotors now hurt ultimate stopping performance, much the same way a treaded tire is worse than slicks. If you look at Formula one, they no longer drill their rotors. Some have even exchanged the vanes for series of small holes...
So, for mall crawlers, get the drilled rotors. For the rest of us, undrilled provide equal or better performance. The high end rotors with directional vanes that pump air thorough the rotors have their place at the track where you get air moving thorough the rotor before the next corner, and drilling may still have a purpose there as it would allow slightly more cooling.
As noted, its pads sitting on the hot rotor that warps. Interesting that ceramic pads don't warp rotors as bad.; I think I can understand the physics - the ceramic doesn't hold any heat, so doesn't cause the heat soak that warps rotor.
