Garth Libre
I just finished doing the job with Dorman's kit and I have to report it had an unexpected complication. The eccentric cam bolt that holds the stick onto the stub shaft came off with great difficulty even using the trick of putting the nut on the other side. Then I couldn't get that nut to release from the proprietary threaded shaft, so I had to go to the hardware store and get two jamb nuts in that same pitch to hold the rod steady, and I still couldn't get the nut to back off. Finally, I heated the nut with a torch in a bench vise and it backed out. I cleaned up the threads and did the install and now it's fine. I spent about 3 hours on this job including time to drive to the hardware store. It's shifting fine and I cleaned up the shifter boot and underneath so it's 2010 factory clean again.
